![]() | Home > Technical (L322) > 2003 v8 zt 5 speed gearbox issue, only had it a week! |
Gbw321 Member Since: 05 Aug 2017 Location: Witham, essex Posts: 29 ![]() ![]() |
Hi, I have just got a 2003 v8 4.4 autobiography which I've always wanted, but has started to develop a fault with the gearbox, seemed to start with it holding revs up and not changing up the box correctly, then goes into transmission overheat, and transmission failsafe. Also noticed that the gear select indicator on the instrument cluster keeps disappearing from the display? At other times seems to drive with no issue, especially when from cold. Have read various different articles all saying different things, any advice would be appreciated
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
If it's driving well from cold I would suspect the oil cooler and rad. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3269 ![]() ![]() ![]() |
Spot on Alistair. Best replace rad and oil cooler for many more miles of happy motoring. |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
if you have got transmission overheat a few times now, you need to get the gearbox oil changed at least. as when it overheats the oil degrade much faster then normal.
Is it a big job to replace those?
Gearbox seems to be getting worse, went out today and it started ok, but the autobox not changing gear and showing Transmission Failsafe in display from start, after a few miles then shows Tranmission Overheat.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817 ![]() ![]() ![]() |
id argue its the main reason folk get rid of these machines pal |
Only just got it, dont want rid of it just yet !
Find local Land Rover indie and ask there cost for rad and gearbox cooler and gearbox oil change.
Well car now booked in next Monday with auto box specia so hope not too major. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
was you planning on eating this month ............? |
Bought it for a very reasonable price, expected to have to pay out on it at some point! |
I made that mistake too |
Be sure to let us know the outcome. ![]() 2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html |
