![]() | Home > Technical (L322) > air suspension reset ? |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
Could be multiple things
Yeah it's a bit off a ball ache to jack up in a normal jack, I always leave a door open or disconnect the battery, just to stop it auto adjusting.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 816 ![]() ![]() ![]() |
batterys off already and it refuses to budge from the bump stops so no worries on that front pal |
Update , new front left height sensor fitted , codes cleared , car immediately leveled out at the front but rear dropped toggle was lit but flick it euther way and it flashes with no movement , been for a drive , no change , pump looks brand new to me , got a new code
Halfway there!
Ok , im using solus and i made a vid of the values , shall i email it to you pal ? |
yeah can do mate,
I take it the only way to check for a leak when its on the bump stops is to jack each wheel up in turn ? |
Update , ive cleared faults and got the passenger side to go up and down but not
Making progress , got the car at level ride height , so went for a drive , bong air susp inactive ! Code is 100 air validation fault , tried 3 times and the same one returns , whats it mean ?? |
Articulation validity?
Ok but both rear height sensor control arma were in poor states , osr was seized on the axle and the nsr is broken at the bottom due to seizeing ( i think ) thow it still works ! So , if neither of those issues can cause that fault then i will try soaping each bag tommorow morning |
Oh and another thing , the new left front height sensor is reading minus when the car is level ?? Wpuld this confuse the susp computer ? |
