Home > Technical (L322) > STRANGE PROBLEM
thegamekeeper
2006 Range Rover Vogue Td6 Java Black
STRANGE PROBLEM
when i go to start it seems theres no power to the key. fuel pump doesnt cut in. and theres no electric to nothing. i started it earlier and the battery light came on so i turned it off and there was no power at all as if the battery was disconnected but i checked and that was fine. its done it a couple of times today and once it did it while i was driving down the street. just like something is cutting all the power. if i turn the ignition key a few times it powers up again. any ideas anyone
thanks
tony Current. FFRR Vogue. TD6 Java black.
2009 Mini Cooper JCW in Black
Gone. 2006 Discovery 3
2008 Nissan Navarad40
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
2 x saphire cosworths
Various Mk1 & 2 rs Escorts (when i was young and mad)
Post #447418 10th Aug 2017 7:31pm
alistairh
check your connections to the battery. Mine did similair recently and was confirmed when i could remove it by hand easily. Ended up having to replace the negative lead and it fixed it..
Post #447421 10th Aug 2017 7:48pm
thegamekeeper
ive checked them mate and they are all tight. but i think its something along them term. i will check all the earths to body and chassis etc tomorrow Current. FFRR Vogue. TD6 Java black.
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
Post #447424 10th Aug 2017 8:01pm
Weegie
Ignition key on its way out? John
GAP iiD BT-Sold
Post #447460 11th Aug 2017 7:47am
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
That was my thought weggie
Post #447462 11th Aug 2017 8:20am
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I had this its the control module at the bottom of the key barrel has to be done by a dealer as has to be coded to the car, its about £60 for the part plus the labor.
Post #447469 11th Aug 2017 9:27am
Weegie
I did mine on my Td6. No coding was required. Straight swap - once you take the top of the console out.
Some information here https://www.aulro.com/afvb/l322-range-rove...tch-2.html re replacing. The thread shows a clean up of contacts.
When I did mine I replaced the switch with new. About £90 IIRC from Dan@Duckworths. John
GAP iiD BT-Sold
Post #447475 11th Aug 2017 10:12am
thegamekeeper
i think its the switch i had to struggle on trying it a few times this morning Current. FFRR Vogue. TD6 Java black.
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
Post #447676 13th Aug 2017 8:08am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Had the same problem with my saab and the mercedes , the key is read as its inserted , if the unit is going bad , no kiss kiss no bang bang
Post #447679 13th Aug 2017 8:26am
