![]() | Home > Technical (L322) > Suspension bushes |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
These are very good!
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1525 ![]() ![]() |
Mixed opinions on polymer bushes. Some opinions being that whilst they stiffen/harshen up the ride initially, they don't have the suppleness long term, leading to them wearing out. i.e. you've paid more on them but they haven't really lasted for a longer time.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Totally agree I replace mine far too often just done them again probably once a year so about 20k but then it annoys me if it doesn't drive true
Some solid advice there from fisha! The arms and joints are a problem with the FF, but it is a big chunk of metal.
SteMY06HSE Member Since: 23 Jun 2016 Location: Doha Posts: 63 ![]() ![]() ![]() |
Hi Busa1400,
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817 ![]() ![]() ![]() |
I will be replacing the rear( largest) bush on mine asap , got the new bush , just need to whip it off to do the job , mine is knocking like mad at certain steering angles |
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 ![]() ![]() ![]() |
Cheers I suspect this is what it is 2011 Range Rover Vogue SE |
Just to be clear ... I would't bother trying to just replace a bush within an existing arm. Just buy the whole arm that includes the bush from the outset. V8 or else ... |
why ever not ? its an easy enough job if you have access to a press |
I suppose if you have a press ... I get where you are coming from ... I'm a cheapskate at times, so do look for the cheapest option ...
well the arm was £88 plus vat from my parts place and the bush was 12 quid , hence why I went that route , big saving to be had , job itself is a bit of a pig off the floor but I managed it , would have been easy with a 2 poster |
