Home > Technical (L322) > Egr error code
Provarmint
England 2007 Range Rover SE TDV8 Buckingham Blue
Egr error code
P140E 21 error code
Error code on my 3.6tdv8, Range Rover vogue, advice on the next step please.
Regards Darren.
Post #448020 16th Aug 2017 10:43am
kbald
Hi Darren what sysptoms are you getting that caused you to have the codes read?? Current 2007 TDV8 Vogue Buckingham Blue
Post #448052 16th Aug 2017 5:53pm
Provarmint
Intermitant judder at low engine revs when partially warm, was actually having gearbox checked and the guy kindly offered a diagnostic check FOC.
Post #448056 16th Aug 2017 6:08pm
rar110
The judder may not be related to the transmission, particularly if you feel the judder when stationary.
Regardless I would be accessing the EGRs for a look, or possibly putting borescope in from the manifold side. I don't know if the EGR cooler would prevent you seeing the valve. ______________________________
Post #448075 16th Aug 2017 9:09pm
kbald
Best place to start would be with the egr valve live data to make sure they are both opening and closing together. This could just be a sensor throwing a fault due to a small electrical issue and be nothing! Have you had any symptoms relating to failing egr valves such as engine management light/system faults ont he dash?? Cant see an egr fault causing a judder though! Current 2007 TDV8 Vogue Buckingham Blue
Post #448164 17th Aug 2017 6:44pm
Provarmint
No system lights or dash warnings.
Post #448195 17th Aug 2017 8:29pm
Provarmint
Both egr valves replaced and new glowplugs, runs like a dream now.
Post #449636 31st Aug 2017 5:28pm
