![]() | Home > Off Topic > Cancelling a new car order |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8128 ![]() ![]() ![]() |
Depends what you've signed......
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
As Alistair says, it's all down to the T's & C's of the contract. The dealer has taken the order in good faith and has committed to buy the same from Jaguar. With a production date of the 8th, the spec will already be locked down by JLR.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1428 ![]() ![]() ![]() |
As Alistair says it depends on what your contract says. Some finance deals might have a cooling off period during which you can cancel, but that would be less likely to apply to the car purchase bit of the deal. So I'd be surprised if you could walk away and get your deposit back.
Do bear in mind that the factory make very, very, little. Apart from body pressings, welding and painting, they simply put together some fairly large scale sub-assemblies which are built off site and then delivered in order to arrive at the track side just in time and fully in sequence. There are no boxes of stock lying around to call on to enable late changes.
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1095 ![]() ![]() ![]() |
Thanks Gents, that was what I thought. I will carefully read the T&Cs, but if I cancel now it will cost me I'm sure.
Good luck to you and hope it all works out |
I bought a car from a dealership
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
Andy -pm sent! |
Thanks for that very helpful message Gary.
