![]() | Home > Technical (L322) > Air con compression only 9.45volts-SOLVED |
| kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335
Yes my AC still works nicely.
| Kylerl322 Member Since: 17 Aug 2017 Location: USA Posts: 5
I have supplied 12v and it doesn't engage, I will probably get a new hose piece with the sensor this go around as well though I know it's in ok order but just want to be sure it will stay working once it's working. I get open circuit when I test the coil on the compressor, as in I get no Ohm reading at all which leads me to believe that it is bad, sad considering the compressor is less than a month old. |
Surely the compressor is under warranty? |
yes are they are sending a brand new unit (not even just a reman) I just don't want the 9-10v to burn out the clutch on this one if that's what happened, bot my old original and reman compressor didn't give me an ohm reading at all on the coil which is why I'm thinking the voltage is frying the compressor |
| All times are GMT |
