![]() | Home > Maintenance & Mods (L322) > Can't access erm access height... {SOLVED} |
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836
The cars been parked up for a time while waiting for me to order some bits up and to drain down the gearbox, anyway with it standing so long the battery started to flag so I swapped it out for my spare. Did the steering reset and set it to off-road height, it was struggling to get up to height so I popped it back to normal waited a few minutes and thought I'll drop it to access (I do this if the cars been standing a while so the air springs don't start to crack from lack of use). Anyway the suspension light for access wouldn't light up and the car didn't drop, so it struggled to raise to max and it won't drop to access - the IIDtool doesn't show any eas faults - any ideas guys...... ______________________________
Bumpy 👍🏻 ______________________________
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
possibly not enough air in the system?..leave it running a bit longer ..
I did have everything closed but a bit confused that the led for access height wouldn't light up.
| zarnd Member Since: 22 May 2014 Location: Kent Posts: 459
I had a fault with mine with no lights on the suspension module and unable to select any height.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Taking it for a drive might wake everything up |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801
I've just dealt with the same.. ended up having to do a battery reset to waken up the system again |
Good advice lads.
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817
im with Alistair on this , drive it and it will sort itself out |
Just been up and all is ok, went down to access then straight up to off road height so god knows what was wrong yesterday.
there is most definitely not doing what it should , off road is a lot higher than normal and low doen is a lot lower than standard ride height , could be your compressor getting tired ? |
| Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74
Thanks, both, for the replies. I'll add that to the list of things for the local indy to look at and start saving up. |
if the compressor is getting tired its only 25 quid to refurb it and its not a difficult job at all pal |
Yeah I refurbed my P38a compressor a few times so I think I'll be doing this one as a precaution.
| All times are GMT |
