![]() | Home > Maintenance & Mods (L322) > 4.4tdv8- Anybody heard of leak cylinder head oil press. plug |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
This is exactly what was written:
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
gonna_go_double_r
ok thanks a lot nino.
do you get any oil in the antifreeze? |
err - didn't check... What is that from?
when i had O rings leak I also had leak from the oil cooler itself which was leaking oil to the outside but also inside into the antifreeze.ended up changing gaskets. check pictures i posted in the "4.4 TDV8 Oil Leak Fix". |
ok thanks Nino I'll check that out.
