![]() | Home > Maintenance & Mods (L322) > oil type please ! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3854 ![]() ![]() ![]() |
I have just bought this to do my next oil change from site sponsors Opie Oils.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Yes indeed it does! . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 ![]() ![]() ![]() |
Thanks for the reply, I might have to go to Halfords as it is really low. What is weird is the differences when you are searching shops, some say use semi-synthetic, some say full... very confusing for amateurs like me...
Just a tip,
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 ![]() ![]() ![]() |
Ditto for checking on level ground. My 4.4 TDV8 uses no oil at all between services. I once checked it in a slight incline and it was if the scale as low on the check screen. Double check first, best not to over fill |
interesting, do they still have dip sticks, sorry not being lazy but nowhere near my car....
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1419 ![]() ![]() ![]() |
There is no dipstick. The electronic gauge reads in whole units, so can exaggerate compared with a dipstick where you see the exact position. I agree with the comments earlier about the importance of doing the check on level ground, the temperature of the oil seems to make a difference too.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
is your car losing oil? seams alloth oil to add between oil changes. as BB and Webbie have mentioned level ground and oil at working temperature. otherwise you may overfill. |
This is confusing, last night I did a check and it was nearly "low" and said add a litre of oil, I tried it again this morning and it said it was now low and I should add 1.5 litres of oil, I am on my way to Halfords to buy some but wanted to ask what a safe amount of oil would be to put in in case the gauge is faulty...should I follow the instructions of what the car asks for ? I can't see any leakage of oil anywhere so I am assuming it may have been low since the last service and I haven't checked it for a long while, slap wrists...
is the oil at the min. now,? if it is i would add 1 liter, start and stop the engine . weit 15-20min and check oil.
Hmm, the different readings could be due to oil temperature if the car is in the same position. You might want to put the car on the high suspension setting and slide underneath it (ideally wearing eye protection) and have a look around to see if there is any sign of an oil leak. If you had lost half a litre overnight one would have expected to see something on the ground.
NIGHTMARE !!! I found a level place checked 4 times and it said add 1.5 litres and was showing low. Went to a helpful Halfords who assisted me ( as I am rubbish with cars ) and after about 30 mins agreed that the oil is low..Added 1 litre as advised by Nino_Nino as apposed to 4 litres and the marker went up and said add .5 of a litre..That sort of made sense so I thought I would monitor it...later this evening went for a run in the car, found a level place to check and the level is now right at the top of FULL but the display says oil level ok...
muppet,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
owners manual says that the oil must be hot, ie running temperature and engine to be switched off for 15 minutes to let the oil drain back into the sump.. ... - .- -.
