![]() | Home > Technical (L322) > water |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1584 ![]() ![]() |
Firstly, what pressure coolant reservoir cap does it have? Look underneath it and see if it has 140 or 200 (kPa). It should be 140kPa. Early models had 200kPa.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 834 ![]() ![]() ![]() |
Yes, I think i saw an earlier post of yours saying you had a 200 cap and it should have been a 140, I immediately checked mine and found I too have a 200 cap
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
The coolant tank is known for hairline cracks in the corners which release a fine spray under pressure. May need a new reservoir. Or check the pipes are tightly connected (jubilee clips etc).
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
As others have said, due to pressure (and also/therefore the temperature) small cracks or splits in the expansion tank, radiator, or any seal or connection can open up and release coolant (you should have coolant not water). This is difficult to track down, but usually is expansion tank , then radiator. .
Thanks for your thoughts guys |
I did make a fitting so I could pressure test the cooling system and as I said earlier I pressure tested the system and it held its pressure.
29psi cap? That's a 200kPa cap. I thought you'd changed to a 140kPa (20 psi) cap. Ron B. VK2OTC
p38arover This vehicle is not being used because I am frightened to use it because of the timing chain noise
I can do most repair work but the timing chain job worries me. Ron B. VK2OTC
I think I'm correct in thinking you could be losing water through the head gasket or the valley pan. worth a check.
yes i did
Mine leaked down the side, too, where the finned tubes connect to the side tanks. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
Well, started to work on it now.
