![]() | Home > Technical (L322) > 200 radiator cap or 140 |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
Re caps advise is only buy genuine ones.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
A 53 plate is meaningless to anyone outside the UK. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35828 ![]() ![]() |
hover your mouse over the little car under the posters username and that will conform year etc... ... - .- -.
Thanks Stan. I used to see the same 53 plate type of thing on RangeRovers.net back when I was Admin over there. It was just as annoying then! |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
ok so I have got another 140 cap to replace the 200 seems to seal ok will keep an eye on her she don't seem any different at the moment fingers crossed will carry 200 cap with me just in case |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I have had a 140 cap on mine for years with no problem and no leaks or split tanks.
great info thanks no problems so far with 140 cap. she seems to be running smoother top hose a lot softer than before .fingers crossed |
Cool, I found it a lot harder to bleed with the 80 deg mod, I had the front raised on a sleeper with the cap off and kept burping the top hose and the bottom hose next to the stat housing and all without chopping my fingers off and it has been fine now for months |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 825 ![]() ![]() ![]() |
Bleeding a system is always a worry for me.
it's definitely a worry in the early Petrol range rovers, the P38 only had to smell a cup of tea and it would overheat and fubar the engine - so i have read anyway, and the FF 4.4 is not keen on getting too hot. |
Overheating was always a worry with them.
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 ![]() ![]() ![]() |
I have a 4.4 Petrol about the same age as this.
hi sounds good no probs with mine so far I wonder if there will be a time I can trust her without lifting bonnet and checking .did you have any issues with gearbox holding gear and not changing up .I have had this issue since the start 80 deg mod helped but she will still do it after an uphill tow .my van is 2 tonns twin axle hobby easy tow for car but realy annoying when car wants to do 80 mph before she will change up to 4th not ideal and a bit sore on the dishes in van . not towed since changing cap though .gearbox flushed and thermo mod new rad took out lower thermo still doing it .mabe just the size of van but she tows realy easy |
OK 2 months with no water problems changed cap took my time bleeding . However a little
