Home > In Car Electronics (L322) > Denso touch screen issue please help
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi my first post on here and I am struggling to find the reason for a recent problem on my L322 2006 Vogue SE I have sound but only radio which is an untuned no signal sound all radio stations say preset 1 2 3 etc I do not have a flashing orange light but constant and I can only select 4x4 info and the on board with computer info and venture cam screen with the touch screen I cannot select DVD , TV, CD, Aux and volume control on stereo will not turn the volume up or down but control on steering wheel works! When I put car in reverse rear cam doesn't engage now either. It's not the Bluetooth module or the Sat Nav or TMC as I have all these disconnected and bypassed via the correct bypass modules . I have t step all fuses and all are ok. I recently disconnect the battery a few times to install a new steering wheel could the issue be a software update fir the infotainment system as the battery has been disconnected a few times. Cheers Jay
Post #448944 24th Aug 2017 2:26pm
welcome to the forum Jay..
did you set the steering parameters when you re-connected the battery? ... - .- -.
Post #448947 24th Aug 2017 2:39pm
jaysta10k
Hi thanks for the quick reply steering parameters do you mean full lock left to right if so yes I did. Anymore info will be appreciated as I am out of ideas and looked through all forums on the internet and tried all most everything!
Cheers
Jay
Post #448949 24th Aug 2017 3:06pm
Weegie
Did you try a hard reset with the battery disconnected? John
GAP iiD BT-Sold
Post #448951 24th Aug 2017 3:19pm
jaysta10k
Hi does the hard reset involve touching the two terminals together after you have disconnected the battery?
Post #448952 24th Aug 2017 3:30pm
Weegie
Yes Thumbs Up John
GAP iiD BT-Sold
Post #448956 24th Aug 2017 4:15pm
jaysta10k
Tried the hard reset didn't make any difference any more ideas please or is it a case of booking it in to the stealers!
Post #448981 24th Aug 2017 8:14pm
i think you have done most things Jay..
maybe the battery is under par..do a drop test on it and see.. ... - .- -.
Post #448985 24th Aug 2017 8:21pm
jaysta10k
Hi mate I have a new battery and has been tested all good. I am thinking the issue could be either the amp or tv module I will disconnect and clean all connections and hen try a bypass on each module and if this fails it will deffo be a trip to the stealers with this issue I think as I would of tried everything.
Cheers
Jay.
Cool
Post #449036 25th Aug 2017 10:05am
sounds like a plan Thumbs Up ... - .- -.
Post #449039 25th Aug 2017 10:32am
jaysta10k
Hi guys still struggling with this issue the bizarre thing is I have power to the stereo I have sound the orange light is not flashing hence cannot be a faulty module I cannot turn volume up or down on stereo but I can on steering wheel control and I cannot select DVD, TV, CD or AUX but I can select rear entertainment screens! My car booked in to stealers in 2 weeks but I would rathe try to sort this myself any more ideas anybody.
Cheers Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #449965 5th Sep 2017 3:25pm
JPJ64
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Hi Jay,
Do you have a fault code reader, or have you tried to upload any patches for the various modules? Just a thought but a tool such as the IID tool might shed some light on the problem and be much cheaper than the stealer who is going to do the same thing and charge you for the privilege
Post #449967 5th Sep 2017 3:59pm
jaysta10k
Hi mate I am thinking of buying a Gap IID tool the Bluetooth model will this enable me to upload patches or software updates etc...
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #449970 5th Sep 2017 4:18pm
JPJ64
Hi Jay,
Yes the GAP tool allows you apply updates. In fact, I think it's almost an essential tool for all full fat owners.
Cheers,
Kev
Post #449986 5th Sep 2017 7:37pm
jaysta10k
Is there anybody out there that might have a clue as to what is still causing this issue I cannot turn volume up or down on stereo knob I cannot access DVD,TV,CD,AUX, VOICE ACTIVATION I only have radio , rear entertainment ,4x4 info, and board computer and I can still use my steering controls also. Coulld it be the Harmon kadon amp as I cannot turn volume up or down and I cannot activate logic 7 or turn up bass treble or subwoofer aswell as speaker fader? Any ideas guys
Cheers
Previous Cars
BMW M3 Carbon Black
Post #450313 8th Sep 2017 8:28pm
