![]() | Home > Technical (L322) > 2004 L322 (BMW V8,ZF 5 Speed) Transmission Fluid Temperature |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
more likely a clogged trans cooler and / or lower rad. Very common No7 - 2003 V8 Vogue |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
I'd start with a temp reading at idle from cold. Mine stays in that 41c range quite a while. We need RRphil to jump in here. I believe normal temp is 100c so 150c is bad. How many miles? How old radiator? What is engine coolant temp and radiator temp? Best to check live values on highway and secondary highways. Also buy the thermostat retrofit to drop overall temps. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1004 ![]() ![]() |
Yes, a faulty sensor is definitely a possibility, though the transmission fluid temperature should be about the same as the engine coolant temperature (100°-110°C) so it would have to be reading 40° or 50°C too high to activate the overheat message. You really need to calibrate the sensor signal somehow. Do you have one of those laser infra-red thermometer thingies that you could point at the transmission’s metal sump pan when it's reading hyper-hot?
Class_5 Member Since: 01 Jan 2017 Location: Yateley Posts: 29 ![]() ![]() |
Really grateful for the prompt replies.
If you have a new radiator then that is ruled out. How do you know it isn't just the transmission cooler thermostat? RRPhil will know if they fail opened or closed. If no one knows I'd just do the transmission thermostat first and see how it changes. Mine cracked from age and was replaced. Plus they are relatively cheap. |
Get this sorted yet? |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
Yes I replaced my transmission cooler which was almost blocked.Radiator was only a few years old but when I had temps read on live feed it was flicking up and down which pointed to the temp sensor also.Got mine from Jpat transmissions for £100 there is a YouTube video which shows you how to fit |
I think Rangeyman has replied to the wrong post.
Wrong post??? When you have your cooler changed ask for it back and stick a hosepipe on the water side it should run through clearly mine just sprayed in my face.That will just confirm wether it was a problem.If I remember it rightly the temp switches around 110 deg so if you are getting readings of 130 it is the temp gauge if the cooler is working fine.If you are changing everything it is not a problem but it is always nice to know what is the main culprit. |
My sincere apologies Rangeyman, I misread your reply.
http://www.roverparts.com/resources/videos...ing-light/ A good video here which shows you how it is done only for me the rear speed sensor retainer screw was incredibly tight and is in a very difficult place I needed a special small ratchet screwdriver to get it out and almost thought it wasn't going to come out at all.Had to laugh when it does not show him taking it out. |
