![]() | Home > Maintenance & Mods (L322) > Dash console lighting |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Q1. Yes.
Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74 ![]() ![]() ![]() |
Thanks, that is helpful, if a bit depressing, as I was hoping not to have to dismantle the facia in the third week of having the car.
Not the sensor I was thinking of. Didn't know there was one their.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1531 ![]() ![]() |
I think the dial back lights are surface mounted LEDs already, but as above the LCD backlights are bulbs which can be replaced. That being said, led replacement don't give off the same even light as filament bulbs so the back ground of the LCD is uneven ... Sometimes it looks crap basically.
It had to go dark to check the lights....
The MOSFET was about £10 I think because you would only be buying very limited qty. Couldn't tell you what the part number is, I read it off the top of the chip itself, then googled it for ages to find a source.
Thanks for the pic, it looks like something I could possibly take on, although I haven't actually got any hot air flow-soldering equipment "yet". I have occasionally used friends to help service smt electronics.
Again, its a long time ago, but I *think* that each of the MOSFETS contain multiple power circuits which are paralelled up to increase the power ... you can see this from how multiple legs are soldered to a single circuit board track. It could be possible that some of the paralleled circuits aren't working ... so reduced brightness. When mine went, it flickered in brightness, and then ended up very dim for a long time.
