Home > Technical (L322) > Yellow light
SinbadRose
Yellow light
Hi all,
I have a small yellow light at the bottom of the speedo next to the 150 mark. It is shaped like the cruise control arrow, but yellow not green. Looking through the hand book says nothing that I can see. and searching on web isn't showing much either. No warning lights or messages have come up. Any ideas?
Thanks for any help.
Post #449259 27th Aug 2017 5:51pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Could you fill in your car profile please, then we will know what year, engine and model hou have.
Post #449277 27th Aug 2017 10:16pm
could be the speed limit warning.... ... - .- -.
Post #449292 28th Aug 2017 8:30am
mjdronfield
As Stan suggests, the speed limit warning is a yellow arrow - mine is set at 80 in the pic below....if yours is set to 150 it could be down there?
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #449303 28th Aug 2017 10:48am
Baltic Blue
The default setting is around max150.
80 is a good place to set it. It is so easy to drift from 70+ to over 80 when cruising on quiet motorways, especially in France. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #449305 28th Aug 2017 11:06am
SinbadRose
Thanks for the reply's, I found it while in north wales. It was the set limit, for some reason it was on 156. Why I didn't get one of these monsters years ago I will never know.
80 seems like a good number, its very easy to go over that with very little right foot Smile
Post #449314 28th Aug 2017 1:27pm
btw you can switch off this function in the dash menu ... ... - .- -.
Post #449316 28th Aug 2017 1:30pm
SinbadRose
Thanks Stan, That is how I found out that was the light Very Happy I need to go through the books again and find everything, Don't think the wife would be happy if I had dinner out there Very Happy
Post #449319 28th Aug 2017 2:10pm
