Home > Technical (L322) > Gearbox advice needed
tnysctt
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Hello all looking for some gearbox advice asap esp if once fuse 37 installed once it is removed will gearbox go bak into drive etc as stuck with no reverse at mo so was hoping to put trans box in neutarl via fuse 37 to move car back then take fuse 37 out to allow the car to limp forward in drive
Thanks in advance for any info
Post #449717 1st Sep 2017 9:31pm
RRPhil
Yes, that's certainly what's supposed to happen when you insert fuse 37 (transfer box shifts into neutral) and then remove it again (transfer box shifts back into range it was in when fuse was inserted).
Phil
Post #449728 1st Sep 2017 11:07pm
tnysctt
Many thanks phil
Had box done inc new TQ and planet gears n less than a yr later and only town miles no towing and on way to holiday destination had a rumble n judder n transfail mode drives forward revs high and no reverse been onto my gearbox specialist who cannot belive it and gottta try n get it to him asap many thanks for the reply
Post #449747 2nd Sep 2017 9:20am
