![]() | Home > In Car Electronics (L322) > Turn off alarm without working keyfob ? |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
Wow - an unfortunate situation that the cylinder breaks &lose the keys at the same time.
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
Hi, thanks for the reply, turning the key works on my 04 but it's not working for the 06 but i think it could be the other faults causing the new alarm button to not sync and the alarm to continue, i don't think having the siren unplugged should upset it ?
| Gold Rover Member Since: 25 Aug 2017 Location: Scotland Posts: 13 |
I was going to suggest using one of the diagnostic tools to switch it off, but I was obviously right, in thinking it would be like teaching you to suck eggs. Is there no-one near you with an 'open' faultmate , save you have to change yours over?
There can only be one Gold Rover surely ?
This is my Gold Rover, there are many like it but this one is mine
A great film and an even better Round !!
Sadly that is a cautionary tale, for those who believe they can get the keys programmed by indies. If the dealer was doubtful about being able to reprogramme my original key, how on earth can an indie programme a new one?
Faultmate lead has arrived ...
Good luck. Hope you get it sorted. |
| Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433
With all early l322 key issues, if when you offer up the ket to the barrel you do not hear any noises (gear lever and steering lock) most of the time it is a EWS (immobilizer) issue, I have been to cars that have had a professional key company make them keys or transponders for alot of money I then attend charge less than half the price and fix the car correctly |
I know for a fact mine isn't an immobiliser problem, as the other key works without issue. It happened after taking too long when changing the battery. What was the main key no longer works and as stated earlier, even the main dealer couldn't get it to pair.
Mine is definitely immobilised, still need to sort out the license on the faultmate but the snap on confirms this.
At least you now know that much |
It's a bit basic for the L322, i have run an ECU scan with the faultmate to list what ECU's are present and it has at least managed to talk to them...
| All times are GMT |
