Home > In Car Electronics (L322) > Shocking standard stereo
p38arover
Australia
Not without knowing exactly what is expected at each pin - and that may mean that you won't see DC voltages (that you can measure with a multimeter) at all pins.
It is a little more complex than you seem to think. I'm not trying to be negative but I probably wouldn't know where to start even if it was my own car.
If you are losing colours on the screen, losing sound, switching off, etc., that doesn't point to an amp fault. I'd initially look for a connection fault inside the head unit.
I'll be heading off to bed shortly (it's 10.40pm) so probably won't see your reply until tomorrow morning. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #449433 29th Aug 2017 1:40pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
every days a school day pal and if you don't ask you wont learn anything ! I does turn itself off at times but the main thing is the sub woofer doesn't work so the sound is tinny as heck and when I start the car I get a loud pop through the speakers before the radio comes on
Post #449434 29th Aug 2017 1:42pm
Weegie
Not sure what system you have but if it is HK Logic 7 you should check that it has been enabled. You do it through the set up screen. It is just a question of selecting it.
If it is the system you have, the standard audio is a bit tinny but the Logic 7 is very much better. John
GAP iiD BT-Sold
Post #449450 29th Aug 2017 4:30pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Bembo have you sorted your issue yet as mines still present similar symptoms to what your experiencing I posted a thread also.
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #449973 5th Sep 2017 4:46pm
bembo449
mines gerrin worse jay , still no base and the sodding thing switches itself off randomly about 7 times per 20 minute journey , doing my nut in pal
Post #449985 5th Sep 2017 7:21pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
That's Range Rover ownership for you!
Post #449988 5th Sep 2017 7:53pm
bembo449
well summat needs doing as I cant stand it as it is , I love music on in the car so need to look at options for replacement . . . . .
Post #450044 6th Sep 2017 1:49pm
bembo449
I don't think this is logic 7 weggie
Post #450045 6th Sep 2017 1:51pm
