![]() | Home > Technical (L322) > rear window issue |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
Is this from using the switches in the front or back?
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1236 ![]() ![]() ![]() |
Could be an issue with the body control module under the passenger seat. Sometimes the circuitry/resistors can fail or connections can get loose.
vmaxer Member Since: 22 Jun 2016 Location: staffs Posts: 110 ![]() ![]() ![]() |
Sorry from using front the not had chance to try back as I have to put the lock on |
Just so I understand, using the switch in the front, the rear windows will go down but won't go back up?
hi no as soon as i put ignition on the rear windows go down |
Sounds like there's either a short somewhere (switches?) or a problem with the BCM.
ok thanks will be gettin stuck in as soon as it stops raining |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180 ![]() ![]() ![]() |
I had a stuck rear window recently. Pulled it down manually with a flat hand while holding the switch.
thanks but it was the first thing i did |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
I'd plumb for the BECM, they have small relays on the PCB which fail...
