Home > Maintenance & Mods (L322) > Faulty traction control
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
I have a fault that just keeps coming back.
I get a message showing on the centre screen "Traction Control System Fault" followed closely by "Special Programmes Unavailable". The orange lights extinguish on the HDC, programme selector and suspension control switch.
Often, but not always, this is almost immediately followed by "Suspension Locked" and then "Suspension Lowered" on the dash display.
Car continues to drive normally down the road. All is reset by ignition (ie it's gone the next time you start the car).
IID isn't finding any fault codes for TCM or EAS
Help!!
Post #450380 9th Sep 2017 1:28pm
Sandyt
I have similar except mine goes into extended mode again no faults - I suspect mine happened when car was valeted with too much fluid on the carpets will be interesting to see what others say
Post #450397 9th Sep 2017 5:25pm
Have you had the car tracking done recently? Sometimes faults along these lines can be thrown up by the steering angle sensor calibration.
If the car is tracked out of true with the wheel slightly out of line then he car thinks it's going round a corner when you are going straight...... confuses it.
There is a lock to lock method of recalibration have a search, might be an IiD tool job tho... There is nothing that can't be fixed with a hammer😜😜
Post #450413 9th Sep 2017 8:49pm
berkshirelad
Interesting... Idea
This has only happened since a steering arm has been changed.
I'll get the tracking checked asap.
Post #450682 12th Sep 2017 11:14am
berkshirelad
Just got back from 6 weeks away and put the beast in to have tracking set.
10mm toe out....
Reset and all seems OK
Post #455977 2nd Nov 2017 10:39pm
