Home > Technical (L322) > wont start after a ECU re sync
Balloonengineer
Hi All
I have a 54 plate L322
I read advice to say re-sync the ecus on hawkeye security settings to improve key fob performance, which I now realise is stupid.
however it now cranks over and won't start and gives an EMS fault code of 1DF5
I presume doing that has lost synchronisation with the immobiliser.
Help! What can I do to resolve things with the Hawkeye (bar somehow towing it to a specialist! )
Located/grounded in Mid Kent!
Best wishes
Glen
Post #450379 9th Sep 2017 12:58pm
Sandyt
Does Hawkey keep a copy of the CCF if so roll back to a previous version and it may well all come back
Post #450396 9th Sep 2017 5:20pm
Balloonengineer
Hi
I don't think so
Glen
Post #450404 9th Sep 2017 6:38pm
holidaychicken
It sounds like you have a similar issue to what I had and I had to resync the EWS immobiliser and the engine ECU. Very easy with my Faultmate or testbook and might even be able to do it with Allcomms . Before I got the Faultmate , guy salmon from Aylesford came with a T4 laptop and did it for me
Post #450468 10th Sep 2017 4:44pm
Balloonengineer
Got it sorted with Angus at AHL engineering Ulcombe (Maidstone) to make the RR talk to itself with his Autologic system.
Great service, recommended.
Post #451519 20th Sep 2017 5:56pm
holidaychicken
good stuff, i have used Angus, he is a top bloke Thumbs Up
Post #451524 20th Sep 2017 6:19pm
