![]() | Home > Technical (L322) > handbrake Q |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816
Probably the automatic adjusters, they let them off to fit the disc then pulling the handbrake should wind them in but I doubt yours will be, they seize up.... Could also be a rusty backplate, the shoes fix to the backplate and these rust out and allow the shoes to move instead of pressing inside the disc....
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817
I reckon that's whats happened pal , the running gear is in really good condition , no real corrosion of any sort , I had the ruddy wheels off earlier to do the height sensors ! doh ! have these got the hole to adjust them threw ?? |
I can't remember, should say in RAVE which you can download from the WIKI...
ha ha , ok pal , I use mine as I leave work , just to shut the gates behind me |
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718
there is an adjustment hole |
cool , that's what I was hoping pal |
