Home > In Car Electronics (L322) > Sat Nav Issue
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
Sat Nav Issue
Morning all 😄
My sat nav has a started to reset to unusual settings. Every time I want to use it it I have to change the region back to UK.
Other settings also change but my stored locations are still there.
Is there anything I can check / change? It's very annoying Censored
Thanks
Post #445120 20th Jul 2017 8:57am
Darryl72
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
I had a similar problem caused by a loose cable, could try making sure its all snug.
Post #445276 21st Jul 2017 2:42pm
have a search there are some threads on here about this I think...... There is nothing that can't be fixed with a hammer😜😜
Post #445290 21st Jul 2017 6:08pm
Fish
It's been a while since I posted but I am still having this problem. I've searched the forum and google in general but not yet found a solution,
I have removed the sat nav unit in the boot and checked the wiring, no evidence of any water ingress and all plugs and sockets look fine.
When I switch on the unit the following has changed:
Country - changed to Belgium
Compass - I normally have it set so I am always heading up but it changes direction
Voice - I normally have the voice guidance turned off but this reverts to turned on
Arrival time - this changes to travel time
No stored locations or previous destinations are lost and nothing is lost on the radio or TV.
I presume there is a permanent supply feeding the unit but would have thought other bits of equipment would have similar problems if the fuse had blown (fuse 49?)
Is there anywhere else to check for loose connections or water ingress or is it likely to be a faulty unit?
Post #450896 14th Sep 2017 10:16am
Shaun_
I had the same issues and like others couldn't find a definitive solution. I lived with it until I updated the DVD and that resolved it. 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #450902 14th Sep 2017 11:49am
Fish
Cheers Saun,
I did an update last year, perhaps I will try and reinstall it to see if that fixes it.
Post #450907 14th Sep 2017 12:11pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Mine is exactly the same and I have a 2011/2012 disc installed with latest firmware these systems are crap and so temperamental I have now resorted to uninstalling mine and use google maps on my iPhone with a decent i phone holder on the dash all looks good. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #450917 14th Sep 2017 3:36pm
Fish
I use my phone sometimes, its just so annoying having a built in system that I have to keep changing the options on when I do use it Crying or Very sad
Post #450928 14th Sep 2017 5:48pm
GGDR
I agree it's a loose lead. When I had my battery disconnected I had to reset the region.
. Cheers, Greg
Post #450944 14th Sep 2017 10:01pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I have sat nav issues in mine whereby I cannot control the sat nav voice volume and the estimated time of arrival is about 11 hours longer than it should be but I can't find anything wrong with it anywhere or any settings that have changed to rectify this.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #450980 15th Sep 2017 10:20am
