![]() | Home > Maintenance & Mods (L322) > Ignition problem |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
Looks like your switch is on the way out. Repacement switch is approx £99 IIRC. Do a search on "igntion switch" Best replace it before it packs in completely . As I know to my cost. |
| Mart67 Member Since: 26 Apr 2016 Location: West midlands Posts: 45
All sorted, £48 from Duckworths!! |
| standupking36 Member Since: 30 Jun 2017 Location: lincolnshire Posts: 76
was it easy to replace? |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
It's not hard, no special tools required, just download Rave from the WIKI, take your time and take pictures as you go.. |
did it come made to your key? or do you get a new blade? |
The switch is separate to the ignition barrel, it's the switch below the barrel that fails so you keep your old key.... Pete
oh ok pete thanks, so with it being notchy, its not actually the key part?? |
Easy change, 1hr max, all you need is a set of torx bits. I only changed the actual switch side of the barrel not the barrel itself. |
| All times are GMT |
