![]() | Home > Wheels & Tyres > Another slow puncture |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8042 ![]() ![]() ![]() |
I used to get this on my old Jeep - there was one particular course that seemed to have very gritty mud - I hate to think what other damaging effects it was having....
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
When I had a slow puncture on mine it was due to some corrosion inside the wheel rim where the tyre bead contacts the rim. The tyre fitter cleaned it up with a flap-wheel and it's been good ever since. 2006MY 4.2 SC
Here you go - I think they used something like this -
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1412 ![]() ![]() ![]() |
I'm surprised you are getting mud between rim and tyre. The only time that has happened to me was in my first Classic when I skidded on ice and hit the back wheel against an earth bank which pushed the tyre off the bead and left earth between them. You'd know if that were happening and the puncture would not be that slow...
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Sounds like it could have been bead sealer Alex 2018 Skoda Kodiaq vRS 2009 Caterham Supersport Race car 2007 M5 Touring 2005 Range Rover Vogue SE Supercharged 2004 SL55 AMG |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 207 ![]() ![]() ![]() |
Thanks for all the info and links such a wealth of experience on here!
Wheels are on their way!
Even with good beads, the forces when you're in ruts can be enough to let some grit get forced in there - so the extra bead seal will help.
Cheers Alistair, just had another search and looks like 285/55/20 fills up the arch I was thinking 255/55/20 as a replacement which should fit comfortably
AJS are sponsors. There are some other options on this thread |
