Home > Technical (L322) > Engine fault
Big Boy R44ROV
Engine fault
Hi All. Engine light came on on my 07 SC. Got the IID tool on it and it says left bank too lean. Cleared the fault but it keeps recurring. Obviously cos the fault isn't rectified. Car is well and regularly serviced and does motorway miles all week so the engine is clean, and spot on.
Any ideas? Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #451320 18th Sep 2017 7:47pm
alistairh
Can be all sorts tbh.. vacuum leaks, Pcv system,bad maf sensor ect. Start with the obvious like the Pcv hoses. General inspection on them and maybe a smoke test to find any leaks
Post #451325 18th Sep 2017 8:11pm
Big Boy R44ROV
All hoses seem good. My son is a mechanic and he's checked, but I just thought there might be something obvious! Don't think it's the MAF as it is only registering the fault on one side and the MAF is a single intake into the SC. Thinking perhaps Lambda sensor???? Tony
2014 SL63 AMG White
Gone:
00 TD5 90 County
97 3.9ES Disco
Post #451328 18th Sep 2017 8:26pm
alistairh
Could be a sensor but knowing a rangey it could be a multitude of things..if you have done a smoke test and tested the fuel trims /fuel pressure/ fuel filters good and alls well then a sensor would be next on my list..
Post #451332 18th Sep 2017 8:53pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
thought IId was as good as dealer level so would pinpoint the fault ??
Post #451336 18th Sep 2017 9:06pm
Danwilderspin
did you ever sort this? sounds similar to mine Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #522476 22nd Jul 2019 3:22pm
Big Boy R44ROV
Yes. All sorted. Lambda sensor. 5 minute job to sort. (well for my lad that is) Whistle Tony
2014 SL63 AMG White
Gone:
00 TD5 90 County
97 3.9ES Disco
Post #522477 22nd Jul 2019 4:10pm
Danwilderspin
maye not the same as me ten as my voltages look about right cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #522478 22nd Jul 2019 4:11pm
Big Boy R44ROV
I didn't check voltages to be honest, but I had a new battery fitted in March. Tony
2014 SL63 AMG White
Gone:
00 TD5 90 County
97 3.9ES Disco
Post #522480 22nd Jul 2019 4:14pm
