![]() | Home > Maintenance & Mods (L322) > Suspension help needed |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Gents problem with the suspension in that I can raise it to high ok standard ok but when I try to lower it it goes into extended mode now if I keep on pressing the button to send it down then it does eventually lower - I am wondering if it is the ECU on the way out - no faults showing any ideas |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
on the compressor there's a little brass air filter..check that it's not blocked or/and drill a small hole through the centre of it ...
Thanks Stan will have a look |
I am thinking it is the "grounded sensor" as it will operate up but always goes into extended mode when asked to go down will have a look later |
The pump is only a year old and the brass filter is clean so I still have the intermittent fault where it won't go to access mode
Yes tried that if I use either the one on the door card or the one on the centre switch pack it does exactly the same
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
I had exactly the same fault on mine. Drilled a hole in the exhaust silencer and all is well. It looked shiny and clean on the outside but the inner surface didn't look so great.
Will have a go tomorrow what bugs me though is that the pump is only just over a year old but hey ho |
All sorted took the pump out and removed the container with the container with the desiccant now the spring that keep it all nice and compact wasn't seated properly therefore the desiccant was being rattled around by the air incoming then exhaust so some had powdered the powder had been blown into the brass coloured breather so after cleaning it out and reseating the spring and making sure the desiccant was tight reassembled and jobs a good un
