![]() | Home > In Car Electronics (L322) > Bluetooth in my 02 L322 Vogue |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1579 ![]() ![]() |
Ok, I've looked at the diagrams and think I have worked it out based on the above thread. Now to go and do it.
I've shorted the appropriate input wires to the VRM to the output wires and it's looking good so far.
It's working. Thank you all.
Hmm, the poor quality may have been due to a flat battery! Did the ULF drain the battery overnight? Ron B. VK2OTC
With a charged battery it seems OK. What is noticeable is when the phone rings, it has a very pronounced click before each ring.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7964 ![]() ![]() ![]() |
That's good news then. When I had a really old Sony mobile I used to get text messages on the car screen too, but that went away when I changed phone to a later one...
horsedentist Member Since: 23 Jun 2017 Location: london Posts: 158 ![]() ![]() ![]() |
I didn't bother with the pairing button in the front just put one in the back compartment once paired it remembers the pairing even if you take the battery lead off. I have nav coder too so I can pair with that if need be. If you have low volume I can recommend adding a little amp though. |
I was wrong. I didn't give it enough time. My iPhone 5 transferred my address book. There's just too many entries in it. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
My iPhone 5 worked fine. If you select phone on the steering wheel the track up down scrolls through the phone book on the single line display under the speedo.
Or just set voice commands for the common numbers like "Dial Home". Don't need to use phonebook or take eyes off the road at all then.....
Yes, I've done that. I was initially confused in that I thought it would be like the iPhone where one asks for the name as saved in the phone (not that the iPhones have ever understood my requests - the Rangie does) and it would read the iPhone contact list. Ron B. VK2OTC
I looked at the phone eject box and decided to mod it rather than replace it. As noted earlier, I incorporated the switch in the box to become the pairing button.
Is it possible to clear the ULF of stored phone numbers?
vitopresto Member Since: 28 Nov 2021 Location: Paris Posts: 1 ![]() ![]() ![]() |
@p38arover
