![]() | Home > Maintenance & Mods (L322) > Strange intermittent noise |
| Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301
Hi all,
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277
Sticking caliper? Check the wheels for temperature after a short run. John
Well it looks like it was the exhaust heat shield which had come loose. |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
Nice find, I was thinking torque converter, it would have been TC if it had been mine ! |
I think there may still be an issue with the TC which is causing the judder under gentle acceleration. |
Have you checked for the caliper? Symptoms like running over a cattle grid, which is similar to what you described, can be caused by a sticking caliper.
Yes, it’s be3n up on the ramp and had everything checked. |
| Dieterf Member Since: 24 Apr 2016 Location: Cape Town Posts: 40
My TC was a rumble under light constant throttle load up a slight incline
Mine was like the cattle grid or the rumble strips at the side of a motorway, not a thump thump. Thump thump could be a worn UJ maybe or suspension arm ?
The main noise has been cured now. It’s more of a feeling than a nois when juddering on acceleration and is very mild. |
Injector maybe, have you got any codes ? |
Thats a great document-Thank You
Following the noise of the heat shield I developed another similar noise. When I checked this was obviously relayed to the rear wheel as it was extremely hot. Turns out the brake calliper was sticking.
| All times are GMT |
