![]() | Home > Technical (L322) > Front diff recall? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1031 ![]() ![]() |
Depends on whether you’re looking at a petrol or a diesel model.
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
Wow! An answer from RRPhil....... |
At 82,000 miles it’s likely that the transmission is on its last legs anyway (assuming the vehicle is still fitted with the original unit) due to valve body wear so I would definitely only go ahead with your purchase if you’re prepared to fork out a further £2k at some point in the future for a re-manufactured unit. Might be in 500 miles time or 20,000 miles time but, the chances are, it’s going to happen. Fluid changes may help reduce the valve body wear (& at least Dexron VI isn’t stupidly priced like the ZF fluid for the petrol models) but the worn valve block bores may already be attenuating the clutch pressures, eventually allowing the clutches to slip (particularly the torque converter lock-up clutch). Sorry to sound so pessimistic, and you may be one of the lucky ones whose 5L40-E went past the 100,000 mile mark without issues, but you should at least be aware of what you’d be taking on.
Thanks Phil |
anorakmark Member Since: 18 Jan 2014 Location: Chatham Kent Posts: 121 ![]() ![]() ![]() |
They say prevention is better than cure. when I sold my P38 to buy a FF 3.0TD vogue, I was so worried about the Diff & Gearbox issues, it almost put me off!!
