![]() | Home > Maintenance & Mods (L322) > L322 front end knocking |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
are these the bits that need to be tightened when the FF is on the ground ? ... - .- -.
| Jdd212 Member Since: 28 Sep 2017 Location: Rotherham Posts: 23
Not sure what u mean by that Stan lol .i changed everything apart from the sway bar rubbers and now got the clunking/knocking from the passenger side |
Think I get which bit your talking about.but I avnt changed those rubbers as yet |
| gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162
Did you use OEM parts, or at least Lemforder or high quality?
Hi m8 ye i got them off ebay from jgs4x4 😐not sure the quAlity but I'm pretty sure that could be my problem aswell as I've got quite a bit of movement on the front /rear arm .to be honest I'm hoping it is them as I've spent so much money on it 😲 |
Apparently OEM parts
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1562
Did you replace the ball joints that fit into the hubs at the same time as you changed the arms ? Those are large and prone to wear and cause vertical play in the joint. You cant easily test this when the car is grounded as the car weight keeps the joint compressed together. I could only see / test for play when the joint was fully split apart and it was under no loading.
Yes m8 changed the lot and suddenly its come back .I'm almost certain now it's the sway bar d bushes and drop links |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817
I too have an annoying knock after renewing the front bushes and drop links , mine just seems to knock for the hell of it ! theres a cobbled road on my way to work and the car doesn't knock at all going over that |
| All times are GMT |
