![]() | Home > Technical (L322) > Battery drained no access to car through driver side, thanks |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Do you have towbar electrics? You can plug a charger into the white socket if you get a plug.
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
I have used in the past the number plate light fittings to power an X5 enough to work the central locking |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
I had the same problem, hooked up my -ve jump lead to earth under the FF, then pulled out the driver's side repeater, cut back the wire sheath and attached the +ve to that, it did melt the wire back to the loom but it got the door open |
(I later discovered a wire tucked under the bumper attached to the +ve terminal - the previous owner must of had the same problem) |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I've read about jacking up the front and connecting a battery to the starter motor main positive and to ground somewhere exposed on the chassis but never tried it or looked at how accessible it is.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Not a lot of help now but it surprises me that as this is a well-known issue, 15mins of effort can give a quick and easy point to attach a battery charger. One of the first things I did to mine was run a fused cable from the battery to a female plug behind the grill. If needed I have a ready made lead to plug in.
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
Like the idea Wayne but aren’t those connectors a bit small for the draw, or are you thinking just to attach a battery charger?
This would be for connecting a battery charger or a solar panel to charge the battery in an emergency, not to jump start the car obviously. Cheap insurance. 2007 TDV8 VSE
