Home > Technical (L322) > Engine Management light and hissing sound, 4.2 S/C
quavey
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Corris Grey
Evening guys, new problem today.
I took the FF 4.2 S/C for an MOT today (simple enough eh?) However its now broken...
It was fine when it went in! However on collecting it after the test it now has the engine management (orange) light on. The car feels very slow but it does sound OK. Throttle response is pretty poor also.
There wasn't a huge amount of fuel in her (90 mile range, no reserve light) so I've stuck £60 in just incase but its not helped.
When I got it home and opened the bonnet I could hear a hissing/vacuum like sound coming from under the plastic cover. The symptoms do feel like unmetered air getting into the inlet system.
I now know how to get the pollen filter housing and the engine cover off ... (lets start simple eh!)
Has anyone got any pointers of what might be causing this trouble from under the cover? Or am I barking up the wrong tree? 2005 E60 M5
2017 L405 5.0 AB
2024 i7 xDrive60
2006 (MY07) L322 4.2 S/C, 2004 L322 4.4 Vogue, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C , 2001 P38 Vogue, 1999 P38 4.6 HSE.
Post #453076 5th Oct 2017 6:11pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Sounds maybe like a leak in the intake system. Take the engine cover off and see if you can pinpoint where the noise is coming from.
Post #453114 5th Oct 2017 9:20pm
quavey
That is where I was thinking, I'm thinking it should be fairly easy to find!
Can I just check, if any other S/C owners are reading a fairly loud hissing under the bonnet is not normal? 2005 E60 M5
2017 L405 5.0 AB
2024 i7 xDrive60
Post #453116 5th Oct 2017 9:24pm
kezbo1981
Not on mine it's not. Unless I'm full throttle accelerating, then it makes a nice screaming noise.
Post #453117 5th Oct 2017 9:43pm
quavey
Great stuff, thanks for that. Will try and investigate in the next few days - annoying really as I wanted to use it tomorrow but looks like we'll be in the pickup again! 2005 E60 M5
2017 L405 5.0 AB
2024 i7 xDrive60
Post #453118 5th Oct 2017 9:44pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
reads like you've split a boost hose to me or could easily have just popped off , as the others have suggested already , I reckon it will be obvs once you are under the bonnet
Post #453129 5th Oct 2017 10:31pm
fisha
Hissing or sucking?
Need the cover off and listening around the various areas of the engine bay. A good tip would be a flexible tube plugged into your ear and the other end moved around the joins ... That will pin point the sound much better. V8 or else ...
Post #453130 5th Oct 2017 11:08pm
fisha
Hissing or sucking?
Post #453131 5th Oct 2017 11:09pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I had an air intake/leak noise under WOT that sounded like it came from behind the glovebox that was a split hose underneath the throttle body. I had no EML and no faults stored but lack of power and fuel consumption was less than 200 miles to a full tank.
Took LR three weeks to find and fix and only after someone on here was helping me with ideas as they were replacing their supercharger on their car did we find it. Two smoke tests and a lot of patience got to the bottom of it.
Fixed and perfect now. When mine started I heard two or three almost banging noises and then an air leak noise when I was under WOT. Yours would have been under load for MOT test...
Good luck Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #453161 6th Oct 2017 9:30am
quavey
It sounds like I'm looking in the right direction then. I've a friend who's going to pop round with a snap on diagnostic tool to get some codes out of it and see whats going on.
I'm going to try and take it to bits this evening and have a look after little man has gone to bed, can't do much with him "helping" 2005 E60 M5
2017 L405 5.0 AB
2024 i7 xDrive60
Post #453172 6th Oct 2017 1:01pm
Dreckly
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hi Quavey,
Any joy with sorting your air leak problem??
Cheers,
Ken 55 S/C L322 Zambesi Silver.....GONE!!
56 S/C L322 Java Black......surviving at present...just!
04 N/A 4.2 V8 S Type Jag
1961 reg 3.5 V8 Bowler Tomcat.....Sold
Numerous Classic (rusty!?!) Minis
Post #453631 10th Oct 2017 9:08pm
quavey
I managed to get 15 minutes on it today. Took the engine covers off and found a fairly big air leak on the pcv valve. So I'm going to start there, I've found reference to someone with similar symptoms and it was the pcv valve So it's got to be worth a try!
I've asked for a price from duckworths and will go from there! 2005 E60 M5
2017 L405 5.0 AB
2024 i7 xDrive60
Post #453663 11th Oct 2017 12:10am
Simgoy
I also have this problem!
Has anyone found the cure for this problem as it driving me insane
Post #453983 13th Oct 2017 10:37pm
quavey
I have a new PCV valve on its way from Duckworths so I'm going to start there. Have you identified where the air leak is on yours? 2005 E60 M5
2017 L405 5.0 AB
2024 i7 xDrive60
Post #453986 13th Oct 2017 10:53pm
Simgoy
My air leak sounds like it’s coming from the back of the engine on the same side as the pcv valve. I have also changed the pvc valve but the leak is still there!.
I have also changed the inlet gasket as I read that this can cause the same problem but it’s not cured the problem
Post #453992 14th Oct 2017 12:06am
