Home > Technical (L322) > Transmission thumping
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
My car has a thumping noise when driving and seems worse when slowing down.
I have all ready changed the rear prop shaft bearing and done a wheel bearing so no there done.
I had a very quick look under the car in my lunch break to check the shaft going from the transfer box to the front diff as heard about pinion bearings going.
Whilst seeing if there was any movement in the shaft the whole transfer case moved up and down now instantly I’m thinking that isn’t right but don’t have enough time to get it up in the air and look until next week.
Anyone else have similar problems I’m wondering if I have an engine or gear box mount gone?
Post #453185 6th Oct 2017 4:04pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hi Mine developed a thump last year - although it was more noticeable when selecting reverse or drive .. turned out was a rear CV joint , perhaps worth a check ?
Cheers
Simon
Post #453186 6th Oct 2017 5:06pm
holidaychicken
Mine thumps when I let off the throttle going slowly and then accelerate again.
I have strapped a web cam under mine to try and find the source, I have rebuilt my transfer box and changed out my front outer cv joints, I have a 6 way electronic chassis ear which shows up as the loudest by the transfer box front output to the prop shaft and I still can't find it. Mine is a harsh bang almost.
I've looked at engine mounts and transmission mounts but I think the only way I'd find it is by putting it on a 4 wheel rolling road or laying under it.
It has annoyed me for years
Post #453216 7th Oct 2017 12:08am
alistairh
Had similar before my front diff coupling and prop failed a few weeks back.. you couldn’t feel any play in front prop at all then it went with a bang.. had been whistling a few days prior to its failure as well.
Post #453256 7th Oct 2017 1:36pm
holidaychicken
Mine has been doing it for about 4 years and never got any worse, part of me has been willing it to finally break so I know what it is but it's not really bad but just sounds harsh when it does it
Post #453263 7th Oct 2017 2:30pm
Nothing to do with the rubber doughnut joint at the front end of the front prop shaft by any chance?
Had similar on my discovery.
Post #453264 7th Oct 2017 2:42pm
holidaychicken
Not sure i have a donut ?
Post #453295 7th Oct 2017 8:05pm
Dreckly
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hi RRV78,
I'm in Threemilestone if you'd like to swing by sometime and I'll have a look with you.
Cheers,
Ken 55 S/C L322 Zambesi Silver.....GONE!!
56 S/C L322 Java Black......surviving at present...just!
04 N/A 4.2 V8 S Type Jag
1961 reg 3.5 V8 Bowler Tomcat.....Sold
Numerous Classic (rusty!?!) Minis
Post #453627 10th Oct 2017 9:00pm
RRV78
Thanks for the offer ken.
I think I’m getting closer to the issue. We’ve ran it down morlaix Avenue in neutral to rule out gearbox and prop shaft and think we’re looking at both n/s wheel bearings.
Post #453633 10th Oct 2017 9:14pm
Dreckly
The offer still stands.
I've recently changed my Transfer Box, TB Oil, Diff Oils and Gearbox Oil so I'm getting quite used to crawling underneath a Fattie.
PM me if you want contact details.
Cheers,
Post #453635 10th Oct 2017 9:21pm
