Home > Technical (L322) > immobiliser problem
razzer
England 2003 Range Rover HSE Td6 Zambezi Silver
immobiliser problem
hi guys, can anyone advise, i went on a short journey yesterday then parked my rangey, five minutes later i got back into it and it wouldnt start, it turned over but wouldnt run. i got green flag to come out and the mechanic went through a sequence of pressing my 3 buttons on the key, unlock, boot open and lock many times then the car started. is there a certain sequence i could follow if this happens again. thanks for looking.
Post #453158 6th Oct 2017 9:03am
holidaychicken
The only time I have had that is when my immobiliser lost sync with the engine ECU and I had to put the engine ECU into learn mode and then send a code from the EWS3D immobiliser and then take the engine ECU back out of learn. I did this with my Faultmate
Post #453218 7th Oct 2017 12:14am
razzer
Thanks for your reply, but took it to a landy specialist and he hooked it up and it turned out to be a dodgy fuel pump
Post #453306 7th Oct 2017 10:11pm
holidaychicken
Your green flag man done an amazing job repairing the fuel pump with the key fob!
Post #453310 7th Oct 2017 10:39pm
Sandyt
Wonder if Green flag could solve my steering wobble with the key fob Laughing
Glad you are sorted
Post #453319 8th Oct 2017 7:09am
