Home > Technical (L322) > popping sound thru speakers when compressor kicks in
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
as above , noticed this a few times when the radio is on , I get a pop thru the speakers as the suspension comp kicks in , also does it when I first start the car , any ideas why ??
simon
Post #453119 5th Oct 2017 8:46pm
fisha
Popping in an amplifier setup is most commonly down to the first amplifier stage picking up erroneous RF signals ... which the motor /it's relay is probably giving off when it kicks in. V8 or else ...
Post #453132 5th Oct 2017 10:13pm
bembo449
ok pal thanks for that , can it be rectified ??
Post #453209 6th Oct 2017 8:48pm
fisha
To be honest, it really shouldn't be doing it in the first place. The amplifier / inputs should be shielded enough to prevent RF noise affecting it.
Is it just a single pop , or is it doing it the whole time the compressor runs? V8 or else ...
Post #453270 7th Oct 2017 2:51pm
bembo449
it just like a single " k'dunk" noise as the comp kicks in thow I have noticed it at other times now too , will try and make a note of whats going on when they occur pal
simon
Post #453513 9th Oct 2017 6:42pm
