![]() | Home > Maintenance & Mods (L322) > Deployable steps |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Power switch in roof panel (next to sunroof switch) or try a battery reset as the ECU may need resetting... |
| Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204
Tried a reset battery took leads off touch together then put back on an hour later still no joy, where’s the power supply from or fuse number you might know or would it go off any other possible feed? Thanks _____________________________________________________
Working now woohoo
