Home > Technical (L322) > Diesel Leak
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Diesel Leak
Noticed a smell of Diesel when I parked up earlier. Seems to be coming from rear of RR
Looking under the RR, I can see a damp patch on the centre of the exhaust back box and Diesel dripping off the rear diff.
I can't see any evidence of a leak ahead of the rear diff and fuel tank looks dry.
Tank is half full and it has been a 2 weeks since I last filled up so don't think it is the filler pipe leaking.
Leak seems to be coming from behind the tank which seems strange to me as all pipes go forward from the tank to the engine.
Going to try and get the RR up higher tomorrow if I can and get right under to see if I can see how diesel is getting on rear diff
Any suggestions on what could be leaking would be appreciated.
Andy 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #454065 14th Oct 2017 9:42pm
Check the FBH (Fuel Burning Heater) pump (Rear Right above upper wishbone) and pipework (from there to tank and to under Left tank cover) .
Post #454074 14th Oct 2017 11:02pm
Andy_J
Thanks Joe I think you are spot on with your suggestion.
I have got the RR jacked up and there is a very sorry in-line pump looking device that is soaked in diesel.
As expected there doesn't seem to any easy way of getting the thing out and replacing it
Has anyone replace the FBH pump? Any tips? 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #454100 15th Oct 2017 10:51am
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I've got no experience but given my own leaks (onto the diff but from the diff seal) I thought I'd look it up.
Looking at the manual it looks quite straightforward ( no removing the diff or exhaust or anything!)
Post #454101 15th Oct 2017 11:13am
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
i had the same problem it was the fbh pump the end had rusted off the pump .
Post #454107 15th Oct 2017 2:29pm
Andy_J
Thanks guys, Instructions make it look easy.
Just wondering if in reality it will be a case of rusty nuts and bolts and rubber pipes that will not release form the pump while trying to get you hand through a 3" gap 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #454139 15th Oct 2017 10:41pm
You can give yourself a bit more space by getting some jacks under the rear subframe and releasing the subframe mounting bolts and lowering (gently) that side.
You will probably have to replace the pipe from the tank and/or pipe to the FBH, which means removing tank covers etc. The piping fixings at the pump are almost impossible to remove in situ, and one time only so new fixings will be needed, and the pump itself will refuse to come out of its rubber mounting (bitter experience!), and the rubber mounting will refuse to come out of its resting place. .
Post #454151 15th Oct 2017 11:47pm
Andy_J
Got the pump changed today. Decided to do it from under the RR. One arm either side of the diff and I managed to get it done.
Not as difficult a job as I thought. Once I got the 8mm bolt out that holds the pump on, one of the ends of the old pump snapped off. This made it easier as I could pull the pump down a bit and cut off the hose clips. Pipes slipped off easily, electrical connector was a bit tricky. The new pump went in the reverse of old one came out.
Old pump was well gone outer casing was well rusted and the pump just fell out of the rubber mount.
No all I need to do is get the fuel senders fixed 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #454980 22nd Oct 2017 9:52pm
Brian Considine
My L322 Vogue 3L seems to smell a little of diesel when the tank gets down to around half - never when full - could I have the same problem ? 2003 Range Rover Vogue TD6
Post #529961 3rd Oct 2019 5:15pm
