![]() | Home > Technical (L322) > TPMS....again |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I had two replaced when i bought my car for the same reason. They told me that they needed to code them to the car. I assumed this was via their box of tricks. Ian |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 ![]() ![]() |
the sensors should self-programme after a 15min drive above 12.5mph...at least that is according to the supplier and what I read online...
Seems straight forward............ |
p-trax Member Since: 30 Dec 2010 Location: Hertfordshire Posts: 261 ![]() ![]() ![]() |
Having not received my new vogue, I was not aware that a TPMS exisited.
Hi,
It is not standard fit. Land Rover Addict
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
Was standard on my 07 4.2 S/C
It's never been a standard fit. It's a factory *option*. If you bought a brand new vehicle, you will have to tick a box. If you bought 2nd hand, then the owner specified it at point of order. Land Rover Addict
Thanks Thrasher, guess I don't have to worry then |
wardpg Member Since: 27 Jul 2008 Location: Preston Posts: 76 ![]() ![]() ![]() |
Was standard on my 2008 vogue Se Ex D1, D2, D3 owner now 2008 TDV8 Vogue SE |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
It sure isn't standard on all FFRR's like Thrasher said it's optional on most - you can check if your new TDv8 has TPMS as standard by going to the Land Rover website and speccing up a car online - if it is standard then the configurator will not let you spec it.
Sounds like you're outside looking in. Or would that be the South Coast of Greenland? ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
I am pretty certain that it was standard on my 07 4.2SC Vogue SE. I am the first owner and I recall (perhaps imperfectly) that there was absolutely nothing that you could tick in the options box. Everything was already on it. |
final clarification from the dealer, not "standard fit"
