![]() | Home > Maintenance & Mods (L322) > diy servicing |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
a "britpart" service set from ebay is sufficient, about £50. fuel,oil,air and pollen filters.
cookie42 Member Since: 09 Oct 2008 Location: preston Posts: 46 ![]() ![]() |
yeah i've seen the sticky and have used britpart in the past on my old disco , just not too sure whether its worth paying that bit more for better quality ? |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
I'd go for a slightly better quality than Britpart - try a local motor factors for Mann+Hummel or UFI. |
Josh Wyatt Member Since: 10 Jan 2011 Location: Oxford Posts: 77 ![]() ![]() ![]() |
On all vehicles I tend to use genuine parts as a matter of course. In some cases OEM equivalent parts are good enough. But, for example - An original air filter from the manufacturer does tend to have a greater surface area than aftermarket parts.
ben2012 Member Since: 10 Jan 2011 Location: West Yorkshire Posts: 54 ![]() ![]() |
I own a defender as well and the chap who looks after my defender won't touch anything from britpart, they don't seem to have the best reputation, like someone else said above either try genuine or 'allmakes' now do a 'premium' or something like that! range which is supposed to be good, they might be worth a try |
think my service set had a britpart fuel and air filter and mann fuel filter... |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
on other LR forums they are often referred to as Sh!tpart |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Yep - defo none critical parts. I'd rather set my nuts on fire than use their bits on anything linked to steering , suspension or brakes.
what about the fuel filter , original at £35 or a mahle at £17 ?
It's worth noting that Land Rover do not make these parts. It's also worth noting that the quality of Genuine parts often leaves a lot to be desired (Especially the BMW parts) - to the extent that some of the 3rd party parts are better quality than genuine because they have been re-designed to not fail within warranty etc. |
yea, land rover will mostly contract it out and add profit to the costs, although you would expect tighter quality control from them.
I've worked in and managed repair shops specializing in MB, BMW, Porsche, and LR in the US and in Europe (including main dealers). You need to do more research. Unless you have too much money. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
SteveM, for us diyer's please do add your view on land rover parts compared to aftermarket. 2004 black Vogue TD6 |
RRRob Member Since: 24 Jul 2010 Location: Bury Posts: 123 ![]() ![]() ![]() |
I service my own and I get the oils and filters from Opie Oils with a club discount. Other consumables that are needed I get from whichever supplier that has the best deal and postage rates going at the time. |
