![]() | Home > Technical (L322) > info button on indicator stalk |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 809 ![]() ![]() ![]() |
does nowt on my vogue ! likely cause ?? |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
It’s |
thanks Si lmao |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Hiya,
Hi Si,
hi pal , im at work till 6pm pal so cant try anything with it but why would anyone disconnect it ?? |
Maybe didn’t see the connector and forgot it was there. Could be a dodgy switch in the stalk...... ______________________________
can the cowel be taken off to look or is it a dash board off job pal ?
It’s the plastic cowl underneath the steering wheel, so I imagine it can be taken off without the dash top having to be removed. ______________________________
hope someone can confirm that , it can whistle if it doesn't come off easy pal lol |
Just looked at the manual and it’s three torx screws only. It says to take off the steering wheel first but I doubt that.... ______________________________
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
if the stalk was disconnected then it wouldn't work at all such as indicators etc... so doubt it would be disconnected. Alex
Like I said I wasn’t sure of the numbers of connectors, but I’ve just looked at an indicator stalk on eBay and it’s plugged directly into the rotary coupler, so no leads to be left disconnected.
OR is it because my head unit is playing up ? it really has a mind of its own as ive previously posted |
