Home > Maintenance & Mods (L322) > Coolant level fluctuating and viscous fan on more often ? po
Sandyt
I had the above and also the heater stopped working anyway lots of messing around and removed the thermostat put in new one exactly same so removed thermostat and will get yet another from landrover but once the thermostat was removed all quiet and the heater has started to work again so if you have the above symptoms and they do seem common it could the the thermostat on the way out
Post #454774 21st Oct 2017 11:47am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
so your saying the stat you got was faulty then pal ?
Post #454789 21st Oct 2017 12:56pm
Sandyt
Yes genuine landrover stat put it in without testing it - assumed it was good - bottom hose didn't warm up this morning so hooked stat out popped it in a pan of boiling water and no movement nothing but it did let out a couple of air bubbles so yep it goes back for a swap
Post #454791 21st Oct 2017 1:08pm
bembo449
its not unheard of for a new stat to be faulty pal
Post #454792 21st Oct 2017 1:09pm
Sandyt
True had them before
Post #454793 21st Oct 2017 1:12pm
bembo449
just irritating as pal . . . . . Mad
Post #454794 21st Oct 2017 1:13pm
