![]() | Home > Technical (L322) > Cruise control ‘jerking’ |
Might be in need of software upgrade Stuart.
Stu365 Member Since: 30 Sep 2017 Location: East Yorkshire Posts: 18 ![]() ![]() ![]() |
Thanks for that, will talk to my independent tomorrow |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
My 2007 FF did exactly that. hunting between the gears. It was fixed by resetting the tyre rolling diameter in the Nav. Might be worth a try. Graham
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Which years come with adaptive cruise?
Local independent did the software update for me (£25) and all perfect now, thanks for the advice |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2764 ![]() ![]() |
If you have an IIDtool, could you extract your ecm's current s/w level please? Mine has a slight hesitation on CC at 110 kph so I'd like to know if mine's ecm is at your level. However as there are 2 later updates than mine I suspect that mine needs updating. |
Sorry I don’t yet have an iDD tool, that is on the list to get though |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Thanks Nino. However I hadn't considered different markets, especially with and without a DPF fitted, so perhaps a futile comparison. |
Blair Member Since: 03 Apr 2017 Location: Suffolk Posts: 72 ![]() ![]() ![]() |
Would love the adaptive cruise on mine. Had it on a Golf, and it was blindingly good! |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 222 ![]() ![]() ![]() |
Had my '12 4.4 TDV8 for about six months now and I've noticed this last two days that when engaging cruise control right after setting off after startup the car surges as if it can't maintain the desired speed. I've noticed it when setting CC to 30kph and 50kph (haven't been able to test other speeds as I'm always starting out in built up areas).
