![]() | Home > In Car Electronics (L322) > L322 Android headunit options |
Covbandit Member Since: 11 Jan 2016 Location: Coventry Posts: 104 ![]() ![]() ![]() |
That sounds like the way l want to go, because l can still see and reset my average mpgs etc. How did you integrate the android into the original loom? Was it using the parrott loom and using the android as a sort of aux input? There is a new bmw flat one out too now the e of bay which is android 6 for under 300.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 ![]() ![]() |
Right there are 2 ways of doing a DSP install, you can get one of those units that will work with DSP and wire it to the boot... however if you're prepared to take a gamble, it should be possible to get the same result by replacing the CD changer with an emulator (aux adaptor) that has phono input, like this http://www.ebay.co.uk/itm/BMW-3-5-7-Series...SwgmJX0qm9
Firstly pain... nah pain is having to listen to eurythmics greatest hits and disneys moana over and over again lol. So basically you just use rcas left and right out of the head unit. And this is the same stereo input as the cd changer supplies. Running power to the head unit would not be an issue and getting an aerial extension to the boot also not an issue and in reality you will have an extra rca sub out to run an extra amp and decent sub in the boot. I would also be able to remove cd sat nav and phone krap to make a bit more room in the boot. But the ibus is the only part l am wondering about? Is that so you do not have to keep turning the head unot on in the glovebox? |
ibus is the digital interface that a lot of the systems in the car run on, if you don't connect the ibus then you'll not get steering wheel functions... but that is about it. As no one has done this it is an unknown as to what the steering wheel controls will do.. I was going to do this, but, my DSP amp drowned in the well and that fubar'd all plans for a quick install, so I had the remove it all and do a rewire in the boot...
You see that is my other option. All the wires are in the boot for all the speakers. If l use 2 3 way crossovers for the front, 2 2way crossovers for tje rear and use a 4 channel amp l can run all speakers bar the front dash speaker. Then l can strip the boot and fit a seperate sub and amp there but is just so much work compared to plug and play. Will jave to get a few more splinters scratching my head whilst l make a decision lol |
Right I get the crossover networks, although not totally necessary, but I don't understand where your getting the 4 channel amp from and why you feel it's necessary when the head unit has a built in 180 watt amp on board...
Oh I also forgot that you don't need the extension lead either, if your prepared to make your own loom, as all the connectors that you need come with the head unit |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 252 ![]() ![]() ![]() |
Would this Android unit fit in a 2006 Vogue? Only I notice that my factory unit looks different to the one in your glovebox picture. |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
2006 + is ford / jag electrics different can of worms |
Ah. OK, thank you.
simonzappia Member Since: 22 Oct 2017 Location: adelaide Posts: 6 ![]() ![]() ![]() |
bobsin's setup sounds like the direction I would like to go... anyone know if this setup works with just eonon headunits? i'd like to use CarPlay and dynavin have a dongle allowing this.. |
has anyone else tried bobsin's setup with other units such ad the dynavin or brash? |
@bobsin, is it possible for you to discribe your setup with more detail? |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 800 ![]() ![]() ![]() |
As above , which patch lead etc ?? Poss make it a wiki if you have time ??
