![]() | Home > Maintenance & Mods (L322) > Front Drive Axle & Rear Differential DRAINING & FILL |
| EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 361
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
...one more - on the other post you mentioned LR copper washers but you've not mentioned these here. I take it this is for the Transfer Case?
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35877
another great 'how to'...wiki'fied.. |
Hey Greg - ONLY THE TRANSFER CASE USES LR COPPER WASHERS Not The Front & Rear DIFF - on these just use PTFE Tape - They are a tight fit - DO NOT PUT TOO MUCH PTFE tape on - you just want a nice tight seal. again hope this helps you . |
Greg - On a Rangie ONLY USE Genuine LR parts - Bolts, nuts / threads / washers - never use third party items and such as hell not from Ebay - hell that would be bad !!!
Roger that.
That's a 14mm allen key right?
| Tight777 Member Since: 26 Jan 2018 Location: Epping Posts: 88
Is it just me that can't see any pics? |
there are no pics..
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587
Why?
I use Aviation Sealant No.3 (Non-Hardening). https://www.permatex.com/products/gasketin...nt-liquid/ Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
| counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182
To add to Emirates 380's excellent post; I have a 2011 TDV8 4.4 and the rear diff is the electronic version. So it's a little bit different from the details above, specifically:
| carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58
I have all the parts to change the front & Rear diff, and transfer case oils. However, I assumed I didn’t have the electronic version of Rear diff, but reading about the square drain plug (which Dan from Duckworths believes I have), I’m now wondering. Is there an easy way to find out which version of Rear diff you have without getting under the vehicle? Chris |
Chris get your VIN and go onto the topix website. In a few clicks you'll find your build sheet which should say.
| All times are GMT |
