Home > Technical (L322) > Dynamic stability control warning
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Just been out in the ff, the dynamic stability control warning flashes up on the dash followed by restricted performance and check suspension height.
Pulled up, switched off engine, restarted and everything went back to normal.
What was it?
Post #454016 14th Oct 2017 12:16pm
Wogger
Am I answering my own question here, is it those wires that come out of the top of the suspension ?
Post #454017 14th Oct 2017 12:33pm
mjdronfield
Isn’t that the adaptive dynamics suspension, as oppose to DSC? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #454020 14th Oct 2017 1:42pm
Wogger
I think you might be right there, I've just checked wires and the seem ok
Post #454021 14th Oct 2017 1:53pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Yep the wires on the turrets are adaptive dynamics - very bumpy ride if they fray.
Have you checked the battery voltage - low voltage or drain can cause the issues you have. (I think) Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #454037 14th Oct 2017 6:39pm
Wogger
Funny you should mention that about the battery, it's booked into my auto electrical establishment next week, coz I can't get the battery terminals to to clamp tightly to the battery posts !!
So I'm guessing the battery is not being charged sufficiently?
I've also been told, by a reliable source it could be the brake pedal switch ?????
I'm sure my eldest son had a similar problem on his RR Sport, but I can't get intouch with him to ask at the moment .
Post #454047 14th Oct 2017 7:38pm
Wogger
Just as an update, this fault was traced to a split turbo hose Shocked
Been repaired, and just done a 300+ mile trip pulling the tin tent to Cornwall with no issues.
Post #455015 23rd Oct 2017 10:02am
Baltic Blue
Is this a 3.6 tdV8 or a 4.4 tdV8 ?? Please.
Cheers
B.B. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #455016 23rd Oct 2017 10:10am
its a 3.6 mike.. Thumbs Up ... - .- -.
Post #455017 23rd Oct 2017 10:40am
Weegie
Just found a split on my top hose this morning after getting reduced performance bongs. 3.6 TDv8. Shocked No real surprise. Wink John
GAP iiD BT-Sold
Post #455018 23rd Oct 2017 10:45am
Baltic Blue
Thanks Stan, not one for my log then.
Cheers
Post #455019 23rd Oct 2017 10:45am
Wogger
Sorry BB just read your post, mines a 3.6 v8
Must say it's performing alot better Thumbs Up
Post #455045 23rd Oct 2017 4:20pm
