Home > Technical (L322) > Steering wheel exit function
Steve67
I've a 2010 vogue tdv8, I can set the steering wheel position and it will change with seat memory. I cannot get it to go to exit position, I've changed the setting to exit but it will not move when I stop and open the door. What am I doing wrong. Thanks Steve.
Post #451190 17th Sep 2017 4:38pm
j_rov
I've noticed this in mine too.
Is it that the Exit function does not include the steering wheel? Mine is pretty much in the mid position when driving.
I don't need it to move when I exit, but it would be nice to know if it should. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #455132 24th Oct 2017 12:59pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
My 2011 4.4TDV8 does indeed move the steering wheel and drivers seat for entry/exit 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #455135 24th Oct 2017 1:39pm
j_rov
out of interest, where do you have your steering wheel when driving? Low, middle, high, in or out?
My chair moves when i open the doors, but only because i've raised it a little (it's all the way back already as i have long legs). __
Land Rover History:
1976 Series 3 2.25
Post #455152 24th Oct 2017 3:23pm
Webbie
My steering wheel is set to sit low when the engine is started. If I open the door with the engine running the steering wheel stays in the low position. It rises to exit position when the engine stop button is pressed. I believe this is how is should work.
Post #455160 24th Oct 2017 5:10pm
Steve67
I have my steering wheel low and out for driving. I have set the seat memory 2 to a different wheel position, so I can kid myself that the exit function works Sad
Post #455196 24th Oct 2017 9:02pm
