![]() | Home > Technical (L322) > L322 Td6 Judder |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 816 ![]() ![]() ![]() |
id drop the oil out pal , cheapest place to start and see if that helps at all |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Was thinking that. I originally was concerned it might be an injector but the engine seems smooth.
or its poss low on oil , single flush should be fine from what ive read pal |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
It took me best part of 2 years to finally nail down a similar issue. My TD6 ran perfectly, great MPG etc but randomly after hard acceleration then stopping quickly I would get a judder. When in neutral the engine ticked over smoothly and acceleration was normal and unaffected. It felt worst when reversing into my garage. Turned out to be an injector. 2007 TDV8 VSE
Maybe that's my issue then. Think I'd be kind of glad if it was as the gearbox scares me to death!
It was an injector. I kept forcing the car to get the judders and then ran diagnostics ( BMW IPNA) to see if I could see a fault. On live values, I started to see a pattern with injector 6 so picked up a very cheap secondhand one and had it reconditioned via ebay. A simple swap and problem solved. Easy job as long as the injector comes out without too much of a fight. I doubt it took me longer than 2 hours start to finish. 2007 TDV8 VSE
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I just cured a similar issue by cleaning the connector on the injector as when I disconnected it there was a little puff of orange dust as I had an injector fault logged. The looms are prone to faults and I wonder how many problems are just the connection that gets rectified when the old injector is unplugged and the new one plugged in .
Was not the loom or plug on mine. In trying to find the fault I actually removed the injector and cleaned the nozzle and needle then checked the spray pattern was correct, all 5 holes were clear. In doing that job I had to disconnect the harness from all injectors before refitting. It never cured the problem. The loom can be checked for continuity and resistance with a simple multimeter, there is a how-to video on youtube. 2007 TDV8 VSE
So when you checked your injector was it not spraying out although the holes were clear ?
My injector appeared to be working fine. I removed it just to check the nozzle was not blocked. https://www.youtube.com/watch?v=NUvWnOd5lFw
Thanks guys. I've got a few things to look at anyway.
