![]() | Home > Technical (L322) > Are these gearbox symptoms terminal??? |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Anyone?? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8128 ![]() ![]() ![]() |
Get in touch with RRPhil |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
If it's torque converter then I would say it's recon box time as when it lets go it fills the GM transmission with debris and if its transmission internals then same outcome I would say.
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
If there is a horrible grinding sound it could be the front prop shaft shredded the splines. Mine did it last week, relativley cheap to fix. |
Thanks chaps, have had the front diff recall done so more than likely recon time |
Don't worry, it's in safe hands if you took it to Cooter |
